1 - 5 of 5 Posts
I have a g body car weighs 3150 with qa1 single adjustables coil overs in the rear, can I run 5.0s on these shocks in the 1/8?? Stock suspension 29.5x10.5w with a 12in rim
Discussion Starter · #4 ·
i guess i need to get some double adj AFCOs..........how are you guys starting off with the settings on the double afcos
ext 1/4 loose? or 3/4 tight?
compression half way? or 3/4 tight?
its a s/s g body 3150lbs
Pretty loose to 1/2 way on extension and pretty tight on compression. All cars need something a little different, but that should get you close.
1 - 5 of 5 Posts
