1 - 4 of 4 Posts
How do the settings work, i.e. first click, full loose ext and full tight compression or ? Having some issues. Good on the ext part but way to soft on the compression. If I turn them more does it tighten both sides?
AWESOME!!! Not what I wanted to hear. So either the shocks are gone or the springs are on the edge of too light. When I let off at the stripe the truck noses over severly and actually unsettles the truck. The suspension is not bottomed out when resting and you can pull up the front end by hand about an inch or so.
1 - 4 of 4 Posts
