1 - 2 of 2 Posts
Considering a set of these that I can get at a very reasonable price, however the website indicates they require QA1 coil over struts...not sure why when the strut attaches to the spindle. Any input on these good or bad? Foxbody application.
Stock Suspension FTW!
They are an excellent piece over stock control arms, especially for someone with a tight budget. The only downfall I see is they are heavy and probably use cheaper bushings on the k-member side. They can be used with any other stock replacement strut, I'm not sure why they put that in the description. If your budget allows I'd recommend looking at the Racecraft stuff.
1 - 2 of 2 Posts
