1 - 4 of 4 Posts
I ahve a sb mopar with 5/16ths soild pushrods and was wondering how strng they would be in comparision to a 3/8 hollow .083 wall push rod.? also what pushrod dia. would you recommend for a soild roller app. with 230lbs seat and 500open?
When you increase the OD of the pushrod it significantly increase the strength over just increasing the wall of your existing pushrod.
Can't answer your exact question, but the 3/8 would be stronger. If it will fit use it. The increased weight has no effect on your needed spring pressure and is only a plus for a happy engine.
Blessings............Ron.
called trend they said 3/8 and thats as big as i can fit. Thanks.
1 - 4 of 4 Posts
