When I was building SS/AH Motors this is jow I did it. Used a die grinder to finesse it.I am not a pro, but what I do is wipe high spot blue over the push rod, turn the engine over. When it no longer leaves blue on the head, it's good to go.
I've had a few like this as well. Very slight rub, can still slip a feeler gauge in there if you work it....I don't make any more room than I need too....less grinding time!!Mine actually rubbed the black off of a couple of my pushrods.
