1 - 20 of 31 Posts
Ok, I'm having my first experience with push-lock hose and it's being a real bitch to get on the fittings!..any tips, or advice? thanx in advance...
I put the hose in the vise just tight enough to hold it in there (dont crush it) and then start the fitting by hand and smack it the rest of the way in with a rubber mallet. If its a 45* or 90* fitting then I put a wrench on the little lip above the barbs before the bend and smack the wrench.
Sounds brutal but it works, especially on the smaller stuff that is harder to get on.
Heat the hose w/ a heat gun
NNNNNNNNNOOOOOOOOOOOOO!!!!!!!!!!!
Motor oil works the best, hold the hose towards the end so that there is no chance of the hose buckling. Use 1 fluid motion, if you stop your stuck. If you are putting a straight fitting on, hold it hip high and push up against a solid surface. If it is a 45 of 90, hold the tube bend lightly in a vice where the flange section of the fitting is solid against the jaw of the vise and push from there. A heat gun is a bad idea, you take too much of a chance on damaging the hose, remember the hose is only rated to take 212 degrees.....
The Enemy
Ive never seen a heat gun that gets to 212 degrees though?
never had a problem,I must just be good?
1 - 20 of 31 Posts
