Is the scooter faster?680 LIFT PUMP GAS 540....MILD....6.32 1/[email protected] WITH A LITTLE SPRAY ....GET SOMETHING WITH SOME COMPRESSION...AND GOOD HEADS....THAT'S MY NEXT MOVE
NO...BUT IT'S CLOSE!Is the scooter faster?
pump gas 548",dart block,crower sportman +.250 rods,4.25 callies dragonslayer,srp +10 cc pistons yielding a 10.74:1 cr
comp solid roller 268/272 at .050,.736/.714 on a 111
isky ez roll lifters [no needle bearings]
AFR 335 heads,114 chambers,isky gold stripe springs
home plenum ported/port matched edelbrock 454-R
pro systems 1070 dominator,hvh spacer
2 1/8 x 3 1/2 exhuast using dynomax ultraflow mufflers
msd 6-al box and dist
ran a best of 1.38 60'er,6.15 at 113,9.63 at 141.8 in good air
