Looking for some input on a torrington thrust bearing set up in a SBF. Who does them? HP loss? Durability? Cost?
you talking about crankshaft or camshaft?Looking for some input on a torrington thrust bearing set up in a SBF. Who does them? HP loss? Durability? Cost?
Crankshaft.you talking about crankshaft or camshaft?
Do you have any info on them from FMS?Pretty much every cup/busch/arca car ran them. You can get them from ford motorsports.
Thanks, both our motors are wet sump. 1 danny b belt and 1 timing chain. so that could be a problemIf Im not mistaking, some are done on the front main cap...if so, it will not clear a oil pump shaft.
P.A.OP,what flywheel are you running?
I use to not check this, but killed the thrust several times before finding the converter was pushing and hitting the flexplate bolts. I want at lest .200 between the converter and flexplate bolts and the pilot on the converter and the bottom of the crank!Did you check converter clearance on engine side. You have to make sure there is clearance between converter pilot and crankshaft. Also make sure there is clearance between converter and flexplate bolts.
