1 - 3 of 3 Posts
I want to know the pros and cons of both a blow thru turbo or procharger. Mostly street driven. I know turbo is more expesive do to headers, am switching to boosted over the winter and want to make the right choice. Thanks for your help.
Custom Engine Shop
It is really about how much work you want to put into it.
Depending on the app and hp a P/C can be a bolt. If you are the bolt on type of dude and need a "kit" P/C maybe the way.
Turbo will require more fabrication, if you can't fab and need everything built the P/C may be better. If you can rock-on!
Do the turbo.
1 - 3 of 3 Posts
