1 - 9 of 9 Posts
As some of you know I have started building some G3 Hemi engines. This project is based on putting a G3 Hemi in my 88 Mustang coupe. As most of my projects do it has spiraled out of control and gone from a street car to drive to work a few days a week to a serious build going after the Modern Hemi Shootout Outlaw class and possibly even Drag Week. This turn in direction has caused me to begin building a 25.2/25.3 chassis as 7.50 with a 25.5 will not be enough to run the car flat out. I have not abandoned the daily driver idea as I have a second hemi that will be 426 cuin and be much more street friendly. I have another coupe or I have become pretty interested in a early Dodge Dakota that is a bit more practical and probably the direction the other build will go. This thread will be about the 400 cuin hemi.
Discussion Starter #2
Hemi intake porn!!!
115780
If you would like a one owner 99 Dakota rt extended cab let me know. :)
I appreciate the offer but if I use a Dakota for the 426 it will definitely be an early Gen1. If nothing else for the lighter weight but I honestly like the more plain body lines.
Weight 👍
Another piece of the puzzle showed up Friday.
117449
  • Like
Reactions: DarkMatter
What ratio and planned rpm range?
Discussion Starter #8
1.75/1.75 8500-9000. I had the rockers made with ball adjusters to give them more strength. Valves are both 8mm. 2.200" Ti intake valve and 1.650" inconel exhaust valve. Cam will be .850-.900 lift range no final specs yet. Waiting to see how the Thitek heads come out.
  • Like
Discussion Starter #9 (Edited)
Another piece of the puzzle showed up yesterday. Man!! These rods look like jewelry everytime I get a set. MGP's machine work finish is second to none. Mirror finish with no tool marks is tough to achieve. Hopefully pistons are almost ready to ship.
  • Like
Reactions: wstidham
1 - 9 of 9 Posts
