1 - 4 of 4 Posts
who makes a good progressive unit for a manual trans ..the reason im posting this is i not sure if letting off the gas between shifts will change the settings or not,i need one that works with this if they offer one....ty
The Edelbrock 71900 controller should work for you....
Intelligent Nitrous Progressive Timer: The progressive nitrous timer system will wait
at its present state if the activation signal is removed. Nitrous progression will resume when the controller is reactivated. The entire nitrous and +12 volt timer system is automatically reset 20 seconds after activation.
Hope this helps.. Steve
Don't let off the gas when you shift!
Sorry, couldn't help myself.
1 - 4 of 4 Posts
