1 - 5 of 5 Posts
is there a horsepower level that you reach where its not a good idea to be progressing the system? example, if i have a fogger jetted up to give me something in the 400-500 hp range can it be progressed safely? I dont really hear of guys with systems set up that big progressing them, most have in the 2-300 range and run multiple kits... if we can make the car take it, is there any reason why it would'nt be a good idea to progress a large kit?
just curious...:rolleyes:
It can definately be made to work. I would run 2 systems unless I was running a class that limited you to one system though.
7531 would be really helpful to work in conjunction with the progressive.
I some classes limited to a single stage we have progressed some jets as big as .046 to .052.... But if you can have two stages, they will out flow and out perform a single every time if set up properly... SJ
1 - 5 of 5 Posts
