1 - 20 of 330 Posts
Thanks Dave at Proformance, Kevin (CAPSLOCK) and Steele Fabrication for putting this deal together. Thanks Corey Wilson also for doing the leg work.
LIGHTS OUT 3
FEB 24-26TH 2012
LEAFSPRING SHOOTOUT
TECH CARD 150.00
4,000.00 WIN
1,000.00 R-UP
300.00 SEMIS
150.00 1/4'S
Single power adder only except 4cylinder or V-6)
No billet heads except NA
SB NA................................................ ........................ ............ 2700 lbs
SB N20 .................................................. ................................ 3100 lbs
add 50 pounds for non conventional
add 25 for extra carb
SB Single Blower/Turbo............................................. ............. 3300 lbs
SB Twins.................................................. ................................3350 lbs
BB NA (Up to 640 c.i.)............................................. ................3000 lbs
BB NA (Over 640 c.i.)............................................. .................3200 lbs*
*No Billet Heads
BB N20 (**3stage max limit on BB N20.**)...................................3325 lbs
add 50 pounds for unconventional heads
BB Single Blower/Turbo( F3/106MM MAX)............... ...................3450lbs
BB Twin Combos (88MM Max) or Single Blower/Turbo over F3/106MM...........3550 lbs
Inline 6 Cyl (Turbo/N2o Combos)........................................... ..-600 lbs
(Deduct from SB blower turbo Weights)
4 Cyl/Rotary (Turbo/N2o Combos)...........................................-800 lbs
(Deduct from blower turbo Weights)
**Inline 6 & 4 Cylinder Boosted Combos are allowed 1 single N2o Nozzle between Turbo/Blower and Intake**
CHASSIS/SUSPENSION:
1.)Leaf Spring Only Suspension!!!
2.) No full chassis car
3.)Can move leafs in and shocks can be in any location.
4.) Frame Notch permitted.
BODY/INTERIOR:
Anything goes as long as at weight, no tube chassis back half cars. Stock Appearing interior.
Must run mufflers(Except Turbo Entries).
No Billet heads (execpt SB NA) ALLOWED!!!
No wheelie bars!!!
Max 275/60 drag radial or 28x10.5 non w slick Sidewall
AWESOME!!!
Im very surprised CAPSLOCK OIL CO. didnt go in on this one.:confused::rolleyes:
I'll be back!!!
Discussion Starter · #9 ·
Mo minimum car count. FULL PAYOUT NO MATTER WHAT........
KEVIN CAPS LOCK
I DIDN'T REALIZE IT WAS YOU THAT POSTED THAT...LOL....I'M DRIVING AND POSTING....OOPS
So what if we didn't make the field last time duck? I saw you we're givin tech card money back can I just get a rain check for FEB race?
KEVIN CAPS LOCK
JUST GET YOUR JUNK READY....SO YOU CAN MAKE THE FIELD. :p
Discussion Starter · #13 ·
FLYING RAYAN DIDNT MAKE THE FIELD..............??????????????
I will give you back the 100.00 so just put 50.00 with it.
Trevor Stripling
I am going to try my best to get there.
Trevor
Should be a great class again, and like how it's posted. Straight to the important parts, payout and weights!!!
BYE-BYE RACING
:party
1 - 20 of 330 Posts
