I have a Procharger F1A, with a 5.73 step-up ratio, 74,000 max rpm. Does anyone know how much horsepower it takes to turn at max RPM ?
The hp consumption is the product of a number of things, the blower will consume less power at a given speed if it is operating at a lower boost level (pressure ratio), provided it isn't way off to the right of the compressor map (blower too small for the engine).I have a Procharger F1A, with a 5.73 step-up ratio, 74,000 max rpm. Does anyone know how much horsepower it takes to turn at max RPM ?
Ron, I spent many years at ProCharger developing superchargers and systems and have done a ton of blower power calculations and tests. Believe it or not, the power consumption numbers are up there. They use a supercharged big block to run in the big blowers because a naturally aspirated one doesn't make enough power to do the job. The little grommets survive because the torque isn't terribly high. HP is the product of both torque and speed.You sure your not thinking of a Roots type blower?
So your saying 2000hp at the flywheel an F3 is requiring 400hp to drive?
Personally, I think your waaaay off. You ever take a look at those 3 little nylon style grommets in a Supercharger Stores drive unit?
Blessings..........Ron.
Thanks for the reply. I had heard before that it would be around 150 HP, just don't remember where I read it. I am probably overthinking the whole thing anyway. The reason I wanted to know is to plug the number into the Gates program to find out the correct frequency number to achieve with the cog belt tension.
Chris, not being harsh, just expressing a different opinion. I discussed this also with ProCharger (can't remember his name but he's in charge of there racing program) what an F3 would consume in power. He said they were not for sure exactly but said it would be less than 50hp for an F3. I tend to think that's more accurate myself. But I'm always opened minded.Ron, I spent many years at ProCharger developing superchargers and systems and have done a ton of blower power calculations and tests. Believe it or not, the power consumption numbers are up there. They use a supercharged big block to run in the big blowers because a naturally aspirated one doesn't make enough power to do the job. The little grommets survive because the torque isn't terribly high. HP is the product of both torque and speed.
-Chris
Blessings for the day...............Ron.
Sorry if my reply seemed harsh, that wasn't my intention. I just wanted to state my credentials so you would understand that I wasn't just fabricating the numbers. I'll do the math for you tomorrow when I get back in the office and have my thermo book at hand. The math is actually fairly straightforward.Chris, not being harsh, just expressing a different opinion. I discussed this also with ProCharger (can't remember his name but he's in charge of there racing program) what an F3 would consume in power. He said they were not for sure exactly but said it would be less than 50hp for an F3. I tend to think that's more accurate myself. But I'm always opened minded.
The actual hp numbers it takes to drive the blowers isn't something that the marketing guys at Procharger care to discuss. Its not that its a bad thing cause all centrifugal blowers take a good bit of power to turn, but that the number starts getting up there as the blower size increases and the numbers tend to scare people a bit. The end result is the big blowers make a ton of power regardless of what it takes to spin them and most people shouldn't worry too much about it.Chris, not being harsh, just expressing a different opinion. I discussed this also with ProCharger (can't remember his name but he's in charge of there racing program) what an F3 would consume in power. He said they were not for sure exactly but said it would be less than 50hp for an F3. I tend to think that's more accurate myself. But I'm always opened minded.
Ok, Ron. Here are the numbers as promised.
They may be a bit rough, but are pretty close. -Chris
My F1A is the 5.73 step-up version and I was going through an 8 rib belt every pass before the cog. I tend to believe the 150 hp number, but 276 hp...???? wowInteresting, I would have figured about 80-100hp for an F1A at full steam.
With a 7.25/3.8 pulley at 7100rpm and F1A I see no belt slip with a spring tensioned 8 rib drive, I woundnt think that drive would turn 200hp but who knows. I do know that the 5.4 F1A takes a lot more belt tension then my 4.1 D1SC thats for sure.
I have had the same belt on my car for around 100 passes, I only replace it once a year because I feel guilty. The ones I take off look like new still. Its a very nicely designed spring tensioner setup with very little tension on the belt.My F1A is the 5.73 step-up version and I was going through an 8 rib belt every pass before the cog. I tend to believe the 150 hp number, but 276 hp...???? wow
