1 - 6 of 6 Posts
What's a fair cost for a f2 procharger and everything needed to make it work. Blow through big block
Some variables are needed to figure that out.
Cog drive or crank drive ?
Those will have very different costs.
Street or race ?
Intercooled ? Air to air or air to water ?
Desired fuel?
Desired hp and et Goal ?
What do you have for existing fuel system?
Existing ignition system ?
Do you have a cam, converter and rear gear for it already?
Crank drive air to air. Sniper fuel pump 1/2 in fuel line stick shift car tko. Street strip. 1000hp pump gas. 496bbc
T/S 368E
My biggest cost isn't the blower & fuel system, it's changing the front of the car to fit all that and the bigger fuel cell.
So don't forget about making every thing fit and changes required!!!
Dry sump pump & tank, radiator, fuel pump, fuel cell, vac pump etc etc.
1 - 6 of 6 Posts
