1 - 4 of 4 Posts
I normally just run my timing locked at 32 deg.
I have a msd 6530 and was looking for what kind of timing to run at see level. street vs strip. low boost 540 6psi @ 7400rpm compression is 8to1 afr heads. heading to drag week and I live at 7000ft now and have no idea about see level timing???
It will make more boost at sea level.
At that low of boost I would normally say leave the timing but since your fuel is going to be off as well when you come down to sea level I would pull a couple degrees until you get the fuel sorted and a plug read on the timing.
1 - 4 of 4 Posts
