1 - 20 of 25 Posts
Or any of you guys in the 6 -7 sec. range
What tire pressure are you guys running? Anyone ever heard of running 4 - 4 1/2 lbs?
we run 7-7.5 on m/t 33x16.5x15 stiffs
I have heard of some that low (4-4.5) but most of the guys I know are in the 5.5-7 range depending on track conditions.
T/S 368E
Hoosier, 34.5 x 17 x 16, 6.00 psi.
We do not have a pro mod, however with a stiff wall tire in most cases you need to run 6lbs of air and up. We run the good year 2078's on our 7 second beretta and I usually run 7-9lbs. Anything less and it will shake like no other. On the other hand a soft sidewall in most cases are designed to wrinkle and work with 4-6lbs of air.
Really it depends the car. and tire design.
Pro mod team i used to crew with we were 5-5.5
I run 6.25 on a loose track and 6.5 on a tight one !!!
6.0 with MT 33x16.5 on 15x15 rim with bead locks
The team I was on in Alaska, we ran 6-7 depending on how the track and weather was, or how old the tires were..........
4 to 5 is not that uncommon on dragsters espically hardtail ones
Alot depended on whether we were on beadlocks or liner rims. Screw blower promod anywhere from 5.5 to 7.5. This is all using 36 in Hoosiers.
5.75 - 6.25 depending on track conditions - 33 x 16 Hoosier on 15 x 15 Weld beadlocks
waiting to make a pass!
Too many factors to make a determination without the facts, i'll run 6.5 on an average track and 7 to 7.25 on a real sticky one:smt067
1 - 20 of 25 Posts
