1 - 4 of 4 Posts
I have two systems first is activated by WOT and then second system by dig-set timer. Now that I have a Pro-Cube I want to wire it up and still use the same things. I don't want to use the Pro-Cube timers but I cant figure it out. My nitrous comes on when the transbrake is released. I need the nitrous to have the same delay as what i have in the box. Thanks
I would go with the pro cube timers. More tunable timer increments than the digisets.
I love mine.
Activate nitrous from transbrake wire. You may need to put a 5 prong relay in line to reverse the outputs.
Timer outputs should have delay.
I would use the timers in the pro cube. It has 3 timers. I use 2 for 1st and 2nd stage and the 3rd timer i use for my shift timer. You can adjust everything from the drivers seat with the flick of a switch.
1 - 4 of 4 Posts
