What would be the best sized header for a 470 inch 3.600 stroke x4.560 bore bbc. planning on making 850+hp. In a pull truck coming out of the hole at 6500 and running to 8800. How much would merge collectors help?
X2.I have been truck pulling for 25 years, every class from the 470ish class you talk of to a national mod fwd. I think a 2 1/4" primary with a 4" collector would work very well for you. On the collectors, that is not a simple answer you really need to tune the choke point diameter and the collector length to see the full potential...
