Has anyone made one? I know a blow thru would be better but just curious if they is a how to to make a boost box
Box or no box, the carb would need the same exact modifications for the power you want to make.Has anyone made one? I know a blow thru would be better but just curious if they is a how to to make a boost box
Could you explain this a little more?Box or no box, the carb would need the same exact modifications for the power you want to make.
A carb bonnet is the same thing as a box execpt for throttle shafts and they really are not a big deal.
I was meaning a pressurized carb box where you use a stock non blow thru carb
Needed more boost.Tried it. The cardboard was strong enough, but the tape let go.
