It's v-banded with a 5" pipe passing into the fender well.What is the O.D. of the inlet?
I've checked the local places and haven't seen anything in 5", 4" is the largest I've seen. A thought I had today, was to get a piece of aluminum the same thickness as the one half of the v-band assembly and just make a block of plate and clamp it down.Go to a plumbing supply store, Home Depot, etc. and get some plastic pvc stuff in the sizes you need. Usually can buy a rubber Fernco adapter to clamp on the turbo inlet and pvc to adapt smaller or cap it off, then drill for a air inlet or compressed air fitting. USE A REGULATOR, or it will blow apart in your face. Usually 10 psi is plenty to locate a leak.
No shit, apparently I'm over thinking it. Good stuff!lol.... duct tape on the inlet! I just did this last weekend. Not the best of course but it worked well enough to find my leak
