1 - 4 of 4 Posts
Im looking at a set of 3055 to replace my 3055s(on a 10" wheel) as it seems nobody stocks them up here and I always have to special order them and its a pain but the 3055 are easy to get. Anyway they dont stock the 9555 just the 9553(12 pairs in stock) according to your website both will work is one prefered over the other and why?
Car is 3700# chevelle low boost 454 running low tens sixty foots have been slow at high 1.4xx
This and a friend in a similar weght car with a n/a 540 running the same ets but could never get the stiffs to work hes tried them twice and everytime they go back to the 3055 it works again dunno if this has to do with the tracks up here or the car. Not sure which tubes hes got tho they been in there for prob 10 yrs.
Home > Strip > Natural Rubber Tube
Natural Rubber Tube
Made Specifically For High Performance Racing Applications
100% natural rubber tubes with an aircraft style removable valve stem that clamps to the wheel. Extremely light weight and durable, these tubes are a must for racing applications. Natural rubber is far superior to other materials because of its ability to conform to sidewall distortion and its resistance to deterioration due to many heat cycles.
100% Natural Rubber
Aircraft-Type Removable Valve Stem
Valve Clamps to Wheel
Extremely Lightweight, Durable
NOTE: Besides being required for air retention, M/T® Tubes will enhance the reaction time, increase stiffness and reduce sidewall shock and deflection when launching.
Click to Enlarge
Material # Part # Size Appx.
Weight Application Buy
Now!
90000000289 9553 9.50-15/16 3.6 24.5 To 28 Diameter with 8.0 To 10.5 tread
90000000290 9555 11.50-15 5.1 28 To 31 Diameter with 10.5 To 11.5 tread
90000000291 9558 15.00-15/16 7.0 31 To 33.5 Diameter with 12.0 To 17.0 tread
Tech Corner
How much will a Mickey Thompson drag slick grow?
More Questions??
Visit our FAQ Section
Copyright © 2012 Mickey Thompson Performance Tires &
From this page on your website the 9553 will go up to a 28/10.5 and the 9555 starts at it looks like either could work. I will also comment on the section width(3055) you have written as being 11.7 on a 10" rim when its like 12.4-12.5 why dont you fix these.
1 - 4 of 4 Posts
