Just stick with Hardblok it worksDoes anybody use bowling ball resin? I've used hardblok several times and it works fine, just hard to fit into small water jackets.. If anyone uses the bowling ball resin, where do you get it from?
new bowling balls are made out of a uerthane resin IIRC. not good with high heat.Does anybody use bowling ball resin? I've used hardblok several times and it works fine, just hard to fit into small water jackets.. If anyone uses the bowling ball resin, where do you get it from?
