1 - 8 of 8 Posts
X275!
How are you guys installing them? I have heard of people gluing/epoxying them in, but wasnt sure if that was the best method or not.
draggin' ass
I have seen 3M window sealer (the black goop) and counter sunk allen head bolts with washers and nuts on the back side. If you really want to do a clean job, cover the seam with the factory trim if applicable.
X275!
Well this car has a fiberglass body so I cant weld to it. The channel that the window lays in is built in a way that I cannot access the backside of it to through bolt it.
Thanks for the tip Micah, might look a little out of place on this car though ;)
"Big Al" Sargent
I used the countersank allen head bolts from Bickel across the top (the only place I could access the backside of the bolts) and used countersank metal screws on the sides and bottom of the windshield. I used a 3/8 thick rubber seal from Bickel, also. When I put my chrome on, it'll look like a factory windshield.
X275!
Discussion Starter · #8 ·
The nut-sert thing has crossed my mind. I have a complete set of those in all the different sizes. I planned on drilling a pilot hole to see how thick the fiberglass is in that area and then make a decision from there.
1 - 8 of 8 Posts
