I have a stock case, 1.76 gear set glide with a sportsman brake that I bought used that I recently had it gone threw and freshened, installed it everything works as it should only problem is that when I set the Transbrake and give it throttle to put on two step the car will roll 3-4 inches forward. Any ideas on what causes this problem and what I can do to fix it! Thanks for an advice and help! Scott
