First off let me say that this is the first Ford I have ever owned. Here is my dilemma. I bought a motor and it already had a JW flexplate bolted to it. Now that we are finally starting to put the car together I have ran into a problem. Like I said I have a SBF motor, a JW ultrabell and trans, .090 midplate and a PTC convertor. I realized that there was some sort of a crank adapter on the back of the crank a few weeks back and I called JW and the lady told me that it had to stay there because a stock Ford flexplate was dished and the one I had is flat so I needed to leave the adapter on there to maintain proper starter to flexplate spacing and convertor spacing, which made sense. Here is a pic of the adapter
I also had bought the JW pilot bushing to adapt the powerglide to a Ford crankshaft. Here it is
The big end slips over the snout on my convertor and the small end slips inside of this "adapter" that appears to be bolted to the crank. My problem is that with the convertor all the way in the pump, the tranny on the dowel pins and pilot bushing in the crank and over the snout of the convertor I have about a 1/4" gap from the bellhousing to the block face. I can turn the convertor but the pilot bushing is stopping the tranny from going all the way up flush with the block. I can take the tranny down and romove the pilot bushing and put the tranny back in and of course it pulls up flush against the block. At this point the converter is approx 3/16" from the flexplate which is perfect, but the convertor snout OD diameter is smaller than the the crank adpater's ID diameter where it is sitting. I am lost! Anyone got any ideas? Or has anyone ever used this crank adapter from JW with their pilot bushing, a powerglide and a SBF?
