1 - 7 of 7 Posts
I have a fresh powerglide transmission with a dedenbear case that is slipping in reverse, it has a pro tree trans brake. Low and high gear work perfect, any idea on what may be causing this problem.Thanks,CW.
How does the brake hold when you load the motor against the trans?
1 - 7 of 7 Posts
