1 - 7 of 7 Posts
How much is too much pressure for an aftermarket case 'glide? I'm already pretty confident mine is too much, and am looking for insight to where to adjust to.
FTI valve body with an adjustable regulator, easy to adjust. Recently switched over to AW 68, as recommended by Chance to tighten up by a few hundred. It tightened up 500. Also sent the Servo pressures up. Averaged out (under power) it measured 276, with a max of 321. At IDLE 184 average and max of 205.
3000# Big block running low-mid 5's in the eighth. 8 clutch high, 6 reverse. 1.80
What would a good ball park pressure to shoot for, regardless of fluid?
Thanks as always
Bad thing is, I changed nothing. Have not adjusted the pressure regulator at all. Maybe debris in there, not sure. I do a 30 pass oil & filter change schedule. Anything is possible though.
1 - 7 of 7 Posts
