Got my glide apart for inspection, I was searching through my glide book by Carl Munroe. And it shows drilling the thrust face lube hole to .110"
Is there any down sides of doing this? Also, the book says drill through only 3/8 of an inch...But the hole is deeper than that. If making the hole larger is recommended by you guys, would it be a good idea to make the whole hole the same size all the way through. Just wanted to ask before I do it! Also it is a TCI reman pump.
