1 - 4 of 4 Posts
I need a new input shaft. Turbo-spline glide. Making 1600 hp with a BBC and nitrous, light weight big tire car. 1.80 gears.
Looking at Vasco and Nasa, any others out there to consider? I have to run standard diameter, not looking to replace my pump, etc. Just plug in a new shaft.
There are shafts that have ring grooves (will fit into stock pump/stator tube) and have better ductility than others and are good for 1700HP. Your car being light weight helps in any case.
Hutch
Hutch,
The shaft I have now has ring grooves. Do you have a specific reccomendation ?
Thanks for the help.
John
1 - 4 of 4 Posts
