1 - 14 of 14 Posts
What is my best available option for putting a PG behind a new style HEMI?
I cant seem to find a bell housing for this application.
Dave
Im pretty sure I read somewhere that the gen3 hemi shares the same trans bolt pattern as a small block, if that's true, you should be in business. Good luck.
Thanks. So a small block 904 would bolt-up also then?
I read somwhere that you needed an adaptor or spacer for a 727
I've got a Turbo400 behind an SRT8 Hemi & I'm using a JW Ultrabell & Flywheel. As already mentioned, Gen 3 Hemi's use the Small Block Mopar bolt pattern for the bell housing.
I know this is old, but what did you do for a converter?
Perfect. No pilot spacer or anything goofy like the ls/th400 combos?
The starter on gen3 is on passenger side. LA engines are a different starter and on drivers side. Reid bellhousing have both starter pockets.
Dragpak challengers have Reid bells from Mopar
Somebody makes them...
Actually the starter on the Gen III can be on either side.. in fullsize trucks it is on the driverside of the engine , in Durangos it is on the passenger side . truck 45FRE/545RFE transmissions have both pockets..
Discussion Starter #13
Thanks. I already built the car, raced the hell out of it and sold it! Went with a JW bell and flywheel for a power glide. Worked perfect. Ran [email protected]
1 - 14 of 14 Posts
