i need help, i think i screwed up. run a big block ford dirt drag truck that only uses 1st gear. i pulled the high gear clutches out of 2nd and blocked the 2nd gear feed in the top of the case. has 1st and rev. but when i went to launch of the trans brake...nothing just neutrals. did i take out 2nd incorrectly. does it have to exist for t.b. usage? removed clutches and piston from high gear drum...empty drum. appreciate any help.
