1 - 3 of 3 Posts
I have a 3000 lb fox body with a 430" sbf with a nitrous plate that I qm going to run a class that we have to run 26x8.5 tires. I have a Ried Case with SBF bell and I have A-1 powerglide that has a 1.76 stock planetary. Im going to take the guts from the A-1 and put into my Ried Case. My motor should make around 750 hp and I will use a nitrous progressive to bring in 300-400 of nitrous. With these small tires I cannot hit it hard out of the gate. Will the stock planetary work for a bit? Trans has aftermarket input shaft and clutches. Do I need a aftermarket Planetary? Who has the best price on them?
Thanks, Allen
1 - 3 of 3 Posts
