Thought ill put this up and possible get some answers .
Motor went on dyno few days ago and had physical timing set at 32deg.
On lap top was showing this as max timing as well, pulled 5 timing out of it on start up and max timing set to 29.
Timing light showed up 30 deg and when ever l adjusted on lap top timing it would go oppose and just didn't seem to do anything what l wanted besides going opposite.
Also had the motor play up at 6800- 7000 was crystal clear before that and dyno sheets showed no sign that it was playing up but could hear it play up .
We checked all we could , even pulling plugs and resetting to .035
We gave up and pulled off the grid and put a 7al on it , put light on it and straight away noticed timing was at 40deg !
Pulled it back to 30 deg , and motor had no more hiccups at those specific rev range .
In the end using basic 7al turned motor to 8000rpm and 34 deg total and was crystal clear no issues.
The thing with this when it was in car l never noticed these issues previous .
Any comments/ideas would be greatly appreciated
