1 - 10 of 10 Posts
I have a glide behind 434bbc with a 91mm turbo with a 9.5" ptc torque converter stalls 4200. When I shift it at 7200 it takes tell 7900 to take the gear motor rpm goes up drive shaft rpm drops.
It flares then pulls the motor back to 7000
How do you post it?
No question. You have a flare shift in your trans. Check all the obvious including the shifter adjustment and band setting. If its all OK , the trans will have to come out and be repaired.
Hutch
1 - 10 of 10 Posts
