So I read a bunch of threads about the power differences between the two cam styles but not anything about with boost, I got a 433bbc solid roller e85 F1R blow thru-, cam specs .756/.737 264/270 113LSA, made 1032hp on on an engine dyno at 15.5lbs at 6500, so there's more power left in it when I actually spinning it to 7k (belt issues, now cogged). This gonna be on the street 80-90% of the time, I have 2000miles on this setup and I ate a crane cam ultra pro lifter, and a couple more were ready to go out, cam lobe and had bunch of cracked k-motion k-1000h springs (825lbs open), it's costing me an engine tear down a cleaning, new parts etc etc. obviously not the ideal street setup, but the repairs are pricy on this solid roller stuff, was considering stepping up to the cheapest jesel lifters ($1500) and different spring (k-motion out of business?) and giving it all another go around, but low-rpm street driving with my spring pressures could eat up the best lifter up...
So the option was put in front of me of going solid flat tappet, way cheaper parts, better street manners, but there is gonna be a power loss, just wanna know what boost does on a SFT vs a SR cam profile (around the same specs), is the power loss more drastic on a boosted setup vs an N/A setup? Any comparable setups out there?
