1 - 15 of 15 Posts
Just wanted to ask some of the more experienced people in here. I have a 14.1 comp 408 windsor and the car seemed to slow with the C16 versus the C12. Is it possible that the higher octane rating would slow a car and can you explain why? Just wanted to add that this is N/A motor. Thanks for any help.
yep..its all about burn rate and timming
FE Ford Specialists
Interdependant variables.
Talk to your fuel supplier.
As noted, burn rate and BTU content are not directly proportional to octane (self ignition/detonation resistance).
Sometimes they need to "lose" on a given characteristic in orer to optimize/improve on another.
That is the problem. You WILL lose power and slow down running c16 n/a from the c12. I actually like c14 for this, but if the tuneup is right, I guess the c12 is fine. Two completely different fuels and burn rates and specific gravity, etc..It is not just about octane.
Ok gentlemen, on a average, a 112 octane fuel, R+M/2 is good to 15 to 1. I never run 112 with a higher compression engine but it is capable of handling without issue, a 116 octane, R+M/2, is good over that and really will work all the way up to 18 to 1. If you run a fuel like 116 in a 13 to 1 motor, you will experience a rich condition, slower burning fuel, higher octane, that equals less performance than if you used the 112. The inportant aspect of choosing fuel is the R+M/2 equation. Research octane + Motor Ocrane divided by 2. You need to use that and research you fuel to get what you need......
Click here http://www.vpracingfuels.com/page469659.html to learn the 4 key properties to selecting the right fuel.
VP C-16 is misused a lot in selecting the right fuel. C-16 is really designed as a blower fuel primarily and in naturaly aspirated applications it's not the best choice. It's designed to handle much higher intake air temps than you will see in a non-blower application.
Blessings...............Ron.
Banned
It all depends on the combo. I ran back to back passes using C-16 and C-12 one day with my 14.8:1 SBC and there was NO difference. I did not touch timing of fuel curve and the weather was identical, passes were within 1/2 hour of each other, and yes, all the fuel was pumped-out and a fresh 5 gallons was put in the cell so there was no mixing. Those are my results, I have seen others slow-down between different fuels though.
Discussion Starter · #14 ·
Thanks guys for all the helpful information. I am gonna run the C12 this weekend to see if it puts me back to where we were running. Am I correct in understanding that the C12 has 108 octane? With cost not being a variable, what would be the best fuel for my combination? Would it run better with the oxygenated 113?
from above......
yes, if you jet for it...
1 - 15 of 15 Posts
