1 - 6 of 6 Posts
What centerline length do you guys use for the "good" and "bad" ports of BBC heads? (I have a pair in my garage, but I'm at work and I'd like to run some numbers at lunch.)
These are from Larry Meaux / MaxRaceSoftware
Int=5.868 Exh=3.303 GM 990 BBC cast-iron Good-Port in ported shape
Int=5.760 Exh=3.303 GM 990 BBC cast-iron Bad-Port in ported shape
Int=5.913 Exh=3.303 GM 026 BBC cast-iron Good-Port in ported shape
Int=5.710 Exh=3.303 GM 026 BBC cast-iron Bad-Port in ported shape
Int=5.975 Exh=3.380 GM 781 BBC cast-iron Good-Port in ported shape
Int=5.820 Exh=3.380 GM 781 BBC cast-iron Bad-Port in ported shape
Stan
Thanks again, Stan. Would anyone care to post some ballpark lengths for common engines? I have a friend who's putting LS3/LSA heads on his motor, and I'd like to run some numbers for him but I can't find the length on the Internet. I know 5.45 is close for most Gen 1 SBC heads, but it'd be nice to have a quick reference of port lengths (and not just for Chevys).
Wow, that's short!
... just happen to be modeling Edelbrock's new BV3 BBC Heads
the Intake Port CenterLine Length = 7.12800
the Exhaust Port CenterLine Length = 5.21500
from PipeMax version 4.40
i need to update that List of Port CenterLine Lengths :
Code:
Formula=>  Average_CSA = Port_Volume_CC / (Port_CenterLine_Length * 16.387)
          --- Examples of Cylinder Head Intake and Exhaust Port CenterLine Lengths ---
--- Chevy Small Block Heads ---
Inches         Inches        Millimeters   Millimeters    ----------  Cylinder Head Description  ----------
Int=5.299    Exh=2.796    Int=134.6    Exh=71.02    GM #3917291 SBC out-the-box shape 1.940-1.500
Int=5.339    Exh=2.818    Int=135.6    Exh=71.58    GM #3890462 SBC out-the-box shape 1.940-1.500
Int=5.168    Exh=2.800    Int=131.3    Exh=71.12    GM #041x SBC Ported in SuperStock shape 1.940-1.500
Int=5.315    Exh=2.850    Int=135.0    Exh=72.39    GM #441 SBC Bowl-Ported & Port Matched shape 2.020-1.600
Int=5.195    Exh=2.785    Int=132.0    Exh=70.74    GM #292 SBC ported 215CC shape
Int=5.410    Exh=0.000    Int=137.4    Exh=0.000    GM #034 SBC cast-iron Bowtie 225CC shape
Int=5.453    Exh=3.023    Int=138.5    Exh=76.78    GM #10207643 LT-1 SBC aluminum in Out-the-Box shape
Int=5.415    Exh=2.978    Int=137.5    Exh=75.64    GM #10207643 LT-1 SBC aluminum in Ported shape
Int=5.432    Exh=2.780    Int=138.0    Exh=70.61    GM #14014416 1.840/1.500
Int=5.490    Exh=3.396    Int=139.5    Exh=86.26    GM #10134363 2.180/1.600 18 degree SBC
Int=5.758    Exh=3.623    Int=146.3    Exh=92.02    GM SB2.2 NASCAR SBC in ported shape
Int=5.794    Exh=3.598    Int=147.2    Exh=91.39    GM SB2.2 12480011 SBC 2.180/1.610 in ported shape
Int=5.503    Exh=3.393    Int=139.8    Exh=86.18    GM LS 5.7 Liter in ported shape
Int=5.488    Exh=3.315    Int=139.4    Exh=84.20    GM LS 6.0 Liter in ported shape
Int=5.591    Exh=3.395    Int=142.0    Exh=86.23    GM L92 casting#823 out-the-box shape 2.165/1.590 valves
Int=5.628    Exh=3.328    Int=143.0    Exh=84.53    GM LS-7 12578449 CNCd OEM shape
Int=5.478    Exh=2.988    Int=139.1    Exh=75.90    GM Vortec cast-iron 10239906 out-of-box shape
Int=5.875    Exh=3.668    Int=149.2    Exh=93.17    GM C5R 12480090 out-of-box shape
Int=5.488    Exh=3.315    Int=139.4    Exh=84.20    GM LS-1 in ported shape
Int=5.433    Exh=2.878    Int=138.0    Exh=73.10    GM LT-4 12555690 in ported shape
Int=5.995    Exh=3.355    Int=152.3    Exh=85.22    GM canted-valve SBC in ported shape
Int=5.265    Exh=2.828    Int=133.7    Exh=71.83    NHRA Stocker 14101081  1.840/1.500
Int=5.985    Exh=0.000    Int=152.0    Exh=0.000    Buick/Dart Chevy SBC 10 deg
Int=5.633    Exh=3.041    Int=143.1    Exh=77.24    RHS 12030  alum 235 CC 2.080/1.600 out-of-box shape
Int=5.487    Exh=3.130    Int=139.4    Exh=79.5    World Products SBC aluminum 2.125/1.600 Ported Shape
Int=5.350    Exh=2.875    Int=135.9    Exh=73.03    World Products SBC cast-iron I037 0804111288E 200 CC  2.020/1.600 Ported Shape
Int=5.475    Exh=2.975    Int=139.1    Exh=75.57    Dart Iron Eagle Platnium 49CC 10710040PF
Int=5.526    Exh=3.058    Int=140.4    Exh=77.67    ProAction SBC 223400035A 235CC 23deg
Int=5.465    Exh=2.888    Int=138.8    Exh=73.36    Pro TopLine 235cc SBC 23 deg in ported shape
Int=5.668    Exh=3.470    Int=144.0    Exh=88.14    Pro TopLine 14 deg 285cc SBC cast-iron in ported shape
Int=5.573    Exh=3.053    Int=141.6    Exh=77.55    Pro TopLine 235 CC SBC 2.080/1.600 SBC cast-iron in ported shape
Int=5.443    Exh=3.285    Int=138.3    Exh=83.44    Dart LS-X Style SBC in ported shape
Int=5.625    Exh=3.103    Int=142.9    Exh=78.82    Dart Pro1 230cc SBC alum out of box shape
Int=5.438    Exh=2.910    Int=138.1    Exh=73.91    Dart Pro1 227 CNC'd DRT018 2.100/1.600 SBC alum
Int=5.728    Exh=3.588    Int=145.5    Exh=91.14    Dart 10 deg SBC alum 2.180/1.550
Int=5.598    Exh=3.605    Int=142.2    Exh=91.57    Dart 18 deg SBC alum 2.150/1.600 max-Ported shape
Int=5.470    Exh=3.015    Int=138.9    Exh=76.58    Pontiac-Brodix 23 deg SBC 10033867 ported shape
Int=5.535    Exh=3.190    Int=140.6    Exh=81.03    Brodix 11x SUPR spec Heads 2.080/1.600
Int=5.450    Exh=3.253    Int=138.4    Exh=82.63    Brodix 12  2.150/1.600 in ported shape
Int=5.968    Exh=3.330    Int=151.6    Exh=84.58    Brodix 12X SBC spread-port in ported shape
Int=5.950    Exh=3.510    Int=151.1    Exh=89.15    Brodix 12X12RP SBC Weld Tech CNC'd 2.200/1.600
Int=5.560    Exh=3.233    Int=141.2    Exh=82.12    Brodix-WeldTech CNC 10XWT SBC 2.100/1.600 out-of-box
Int=5.641    Exh=3.393    Int=143.3    Exh=86.18    Brodix 18 SBC CNCd 2.180/1.625
Int=5.515    Exh=3.008    Int=140.1    Exh=76.40    Brodix Track 1 SBC in ported shape
Int=5.899    Exh=3.545    Int=149.8    Exh=90.04    Brodix SBC EB2200 13.5deg 284.5cc
Int=5.571    Exh=3.318    Int=141.5    Exh=84.28    TFS-LS1 Style SBC CNCd Chambers & VJ out-of-box
Int=5.825    Exh=3.513    Int=148.0    Exh=89.23    All Pro 245 SBC 22-23 deg out-of-box shape
Int=5.579    Exh=3.305    Int=141.7    Exh=83.95    All Pro 245 SBC 22-23 deg CNCd & Ported
Int=5.430    Exh=3.260    Int=137.9    Exh=82.80    All Pro LS-X SBC in ported shape 2.055-1.600
Int=5.663    Exh=3.290    Int=143.8    Exh=83.57    AFR 00002418 LS-x out-of-box shape
Int=5.333    Exh=2.900    Int=135.5    Exh=73.66    AFR 210cc CNC 23 deg SBC
Int=5.494    Exh=2.884    Int=139.6    Exh=73.25    AFR 220cc older version 23 deg SBC 2.080/1.600 Ported shape
Int=5.318    Exh=2.950    Int=135.1    Exh=74.93    Canfield SBC 23-500-65 in ported shape
Int=5.576    Exh=3.474    Int=141.6    Exh=88.24    TrickFlow TFS-SBC-5 aluminum 2.150/1.625 in ported shape
Int=5.712    Exh=3.493    Int=145.1    Exh=88.72    Edelbrock 18deg aluminum 2.225/1.600 in ported shape
--- Chevy Big Block Heads ---
Int=7.145    Exh=4.533    Int=181.5    Exh=115.1    Alan Johnson 13 deg BBC Billet Head CNC'd 2.400/1.900
Int=5.123    Exh=4.398    Int=130.1    Exh=111.7    BAE Hemi VI Billet Head CNC'd 2.400/1.900
Int=7.080    Exh=4.158    Int=179.8    Exh=105.6    Sonny Leonard BBC 14.5 deg GPD in Ported Shape
Int=7.050    Exh=4.158    Int=179.1    Exh=105.6    Sonny Leonard BBC 14.5 deg BPD in Ported Shape
Int=6.473    Exh=4.323    Int=164.4    Exh=109.8    Dart Big Chief 18 deg BBC Good-Port in ported shape
Int=6.451    Exh=4.323    Int=163.9    Exh=109.8    Dart Big Chief 18 deg BBC Bad-Port in ported shape
Int=6.611    Exh=4.446    Int=167.9    Exh=112.9    Dart/Olds 14 deg BBC Good-Port in CNCd shape
Int=6.522    Exh=4.446    Int=165.7    Exh=112.9    Dart/Olds 14 deg BBC Bad-Port in CNCd shape
Int=6.904    Exh=4.638    Int=175.4    Exh=117.8    Dart Big Chief 11 deg BBC Good-Port in CNCd shape
Int=6.817    Exh=4.638    Int=173.2    Exh=117.8    Dart Big Chief 11 deg BBC Bad-Port in CNCd shape
Int=6.755    Exh=4.485    Int=171.6    Exh=113.9    Dart Big Chief 11 deg BBC Good-Port in CNCd shape ( latest design 2011 )
Int=6.740    Exh=4.485    Int=171.2    Exh=113.9    Dart Big Chief 11 deg BBC Bad-Port in CNCd shape ( latest design 2011 )
Int=6.124    Exh=3.590    Int=155.6    Exh=91.19    Edelbrock-24 degree BBC Good-Port in ported shape
Int=6.030    Exh=3.590    Int=153.2    Exh=91.19    Edelbrock-24 degree BBC Bad-Port in ported shape
Int=6.200    Exh=3.865    Int=157.5    Exh=98.17    Edelbrock-GM 14044861 BBC Good-Port in ported shape
Int=6.115    Exh=3.865    Int=155.3    Exh=98.17    Edelbrock-GM 14044861 BBC Bad-Port in ported shape
Int=6.028    Exh=3.673    Int=153.1    Exh=93.29    CFE-BMF 385CC CNC'd BBC Good-Port 245-Porting
Int=5.868    Exh=3.673    Int=149.1    Exh=93.29    CFE-BMF 385CC CNC'd BBC Bad-Port  245-Porting
Int=6.068    Exh=3.513    Int=154.1    Exh=89.23    Merlin Grumpy cast-iron BBC Good-Port in ported shape
Int=5.945    Exh=3.513    Int=151.0    Exh=89.23    Merlin Grumpy cast-iron  BBC Bad-Port in ported shape
Int=6.120    Exh=3.448    Int=155.5    Exh=88.39    Dart-Pro-1 325CC BBC Good-Port in ported shape
Int=6.013    Exh=3.448    Int=152.7    Exh=88.39    Dart-Pro-1 325CC BBC Bad-Port in ported shape
Int=6.120    Exh=3.501    Int=155.5    Exh=88.93    Dart 308CC Iron_Eagle Good-Port in ported shape
Int=5.983    Exh=3.501    Int=152.0    Exh=88.93    Dart 308CC Iron_Eagle Bad-Port in ported shape
Int=5.957    Exh=3.525    Int=151.3    Exh=89.54    GM 1077 D-Port BBC alum GPD in ported shape no exh vane
Int=5.815    Exh=3.525    Int=147.7    Exh=89.54    GM 1077 D-Port BBC alum BPD in ported shape no exh vane
Int=5.868    Exh=3.303    Int=149.0    Exh=83.90    GM 990 BBC cast-iron Good-Port in ported shape
Int=5.760    Exh=3.303    Int=146.3    Exh=83.90    GM 990 BBC cast-iron Bad-Port in ported shape
Int=5.913    Exh=3.303    Int=150.2    Exh=83.90    GM 026 BBC cast-iron Good-Port in ported shape
Int=5.710    Exh=3.303    Int=145.0    Exh=83.90    GM 026 BBC cast-iron Bad-Port in ported shape
Int=5.975    Exh=3.380    Int=151.8    Exh=85.85    GM 781 BBC cast-iron Good-Port in ported shape
Int=5.820    Exh=3.380    Int=147.8    Exh=85.85    GM 781 BBC cast-iron Bad-Port in ported shape
Int=6.192    Exh=3.496    Int=157.3    Exh=88.80    Patriot Perf alum 320 CC 2.300/1.880 Bad-Port in ported shape
Int=6.421    Exh=3.496    Int=163.1    Exh=88.80    Patriot Perf alum 320 CC 2.300/1.880 Good-Port in ported shape
Int=5.813    Exh=3.580    Int=147.7    Exh=90.93    ProFiler alum 320 CC 2.300/1.880 Bad-Port in ported shape
Int=6.025    Exh=3.580    Int=153.0    Exh=90.93    ProFiler alum 320 CC 2.300/1.880 Good-Port in ported shape
Int=6.121    Exh=3.462    Int=155.5    Exh=87.93    Pro TopLine RHS BBC cast-iron heads 2.300/1.880 Bad-Port in ported shape
Int=6.407    Exh=3.462    Int=162.7    Exh=87.93    Pro TopLine RHS BBC cast-iron heads 2.300/1.880 Good-Port in ported shape
--- Chrysler Heads ---
Int=6.475    Exh=4.335    Int=164.5    Exh=110.1    Chrysler Hemi 2006 NHRA ProStock 2.550/1.822
Int=4.660    Exh=3.208    Int=118.4    Exh=81.48    Chrysler Hemi Indy Legend in ported shape
Int=5.958    Exh=3.968    Int=151.3    Exh=100.8    Chrysler Zeus P4532847 2.200/1.600 CNC'd shape
Int=5.875    Exh=3.915    Int=149.2    Exh=99.44    Chrysler Zeus P4532847 2.200/1.600 max-Ported shape
Int=5.965    Exh=3.905    Int=151.5    Exh=99.19    Chrysler W8 ProStock Truck in ported shape
Int=6.288    Exh=4.020    Int=159.7    Exh=102.1    Chrysler P5 Hemi ProStock Truck in ported shape
Int=4.093    Exh=3.123    Int=104.0    Exh=79.32    Chrysler Hemi 2780559-M cast-iron NHRA Stocker
Int=4.948    Exh=3.140    Int=125.7    Exh=79.76    Chrysler 596 cast-iron out-of-box shape
--- Pontiac Heads ---
Int=5.163    Exh=5.623    Int=131.1    Exh=142.8    Edelbrock-Pontiac alum out-of-box shape
Int=5.305    Exh=5.488    Int=134.8    Exh=139.4    Pontiac CV-1 Roland Racing in Ported shape 2.250/1.720
--- Ford Heads ---
Int=5.032    Exh=3.015    Int=127.8    Exh=76.58    Ford SBF alum AFR CNC'd 2.080/1.600
Int=5.625    Exh=3.524    Int=142.9    Exh=89.51    Ford BBF D2OE-AB 2.250/1.770
Int=6.465    Exh=5.126    Int=164.2    Exh=130.2    BBF Blue Thunder Thor 2.480/1.850
Int=5.873    Exh=3.571    Int=149.2    Exh=90.70    Edelbrock SBF Glidden-Victor GV2 CNC'd shape 2.200/1.600
Int=5.788    Exh=3.228    Int=147.0    Exh=81.99    Edelbrock SBF #7721 Ford out-of-box shape
Int=5.953    Exh=3.685    Int=151.2    Exh=93.60    Edelbrock SBF #7731 Ford CNC'd 2.200/1.600 shape
Int=5.135    Exh=2.995    Int=130.4    Exh=76.07    Ford Edelbrock Victor Jr 2.055/1.600
Int=5.145    Exh=3.290    Int=130.7    Exh=83.57    Ford TrickFlow Street-Heat aluminum in Ported shape
Int=5.828    Exh=4.408    Int=148.0    Exh=112.0    Ford TrickFlow A460 Bowl blended VJ 2.400/1.920
Int=5.295    Exh=4.478    Int=134.5    Exh=113.7    Ford M6049C3 ported shape 2.150/1.600 2nd design
Int=4.979    Exh=4.317    Int=126.5    Exh=109.7    Ford M6049C3 ported shape 2.150/1.580 1st design
Int=5.065    Exh=0.000    Int=128.7    Exh=0.000    Ford SBF Boss 302 242CC Ported
Int=4.873    Exh=0.000    Int=123.8    Exh=0.000    Ford C9OE SBF 351W 148.1 CC
Int=5.078    Exh=3.943    Int=129.0    Exh=100.2    Ford CHI 3V 218cc 2.190/1.655 ported form
--- Honda Heads ---
Int=3.753    Exh=3.605    Int=95.33    Exh=91.57    Honda S2000 4-valve
Metric Conversion=>  Inches = MilliMeters * .039370079
i looked thru all my Flow test files , i've Ported a bunch of LS3 Heads , but unfortunately, i did not measure any of their Port CenterLine Lengths
should be close enough to LS-7 ??
just get your HeadPorter to measure his LS3's
Example=> Roof= 4.200 Floor= 2.200 Total= 6.400 / 2 = 3.200 Port CenterLine Length
( use Scotch 3M 218 Fine Line Tape to measure Roof and Floor Lengths )
Thanks Larry, that's very generous of you!
1 - 6 of 6 Posts
