1 - 20 of 38 Posts
I have a submersible well pump. Tonight my wife called me down to the basement and said that the pump sounded funny, she was running the washer. I have a cut out in my basement and the well casement is inside that cutout, so i can hear the pump run when I am in the basement. I noticed that the pressure on the gage was around 30 psi and was not climbing. So I shut off the main water valve to the house and it really didn't seam to help. I then turned the pressure switch off to stop the pump.
I noticed the pressure gage went almost right to zero. I left it sit a few minutes and turned the pump back on at the pressure switch. It built pressure up to 50psi at it's normal rate. I flushed the toilet and ran some water to cycle the pump and it worked fine. I did that 2 times and it was all ok.
So later she got into the shower and when she was done the pump was doing the same thing again. Running but not really building pressure. I flipped the power off and the pressure started dropping again. I left it off a few minutes and started it again. It went right up to 50PSI.
So I am assuming the pump is bad, Maybe the foot valve???
Any ideas???
Keith
Yea, Kevin I was thinking the same thing. If I pull it I am replacing the entire thing. I have been here for 13 years so i know it's at least that old. I was hoping someone had a quick fix.L.O.L.
Keith
Banned
more than likely crap in the impeller-sometimes just shaking the pump up and down while its off frees up the junk
you more than likely also have a check valve in the line coming out of the pump that could be hangin up
There is (what looks like) a check valve in line right before the pressure switch. Maybe I should try to replace that before I pull the pump.
If I need to pull it, any tips or tricks to make that happen with out alot of drama??
Keith
all motor
remove the hose clamps around the check valve and the pump should pull out. I'm thinking there may be plastic or something that is getting sucked up into the screen when the pump cycles on. When its off, the plastic returns to the bottom and thus you get the normal pressure for a minute...
Discussion Starter · #9 ·
For sure if I have to pull it, even if there is just trash stuck in it, there is a new one going back in.
Keith
you have 2 check valves 1 on top of pump 1 at your tank that will let it run back into the well. put your pump should still make pr . a pr problem is a week pump,low well or a leak in the pipe in your well.
Discussion Starter · #13 ·
After a long draw, when the pump is not building pressure, if i turn the house supply off and shut the pump off the pressure will drop semi-fast and steady. Once i let it sit a few minutes and re-start the pump it will build pressure and hold it.
Keith
Discussion Starter · #14 ·
If it was a low well wouldn't the water be dirty??
keith
Banned
Keith
if the check valve is working properly it should hold pressure on the house side of the check valve as long as all valves{faucets}and toilets arent letting water pass
if you can undo the line at the check valve on the pump side-and then turn on the pump and check pressure on that side do so
if you find yourself putting in a new well pump,wrap it around the inlet with a layer of mesh,itll keep crap from getting into the pump and act as a filter
ROLL TIDE!!!!
Was gonna say that, too. Easier to check that check valve than to pull the pump, right?
Banned
depends,if he has a pump that resembles a pool pump then it would be serviceable but hard to prevent debri from coming up the inlet again without installing inline filters
other pumps resemble drop in sump/sewer pumps and can be hoisted up by the 1 1/2 pipe that screws into the top of it-those usually arent serviceable-excluding replacing the float switch-but usually you get stuck buying a new pump
Discussion Starter · #20 ·
So...it will hold steady pressure for a long time? But only until something else starts running?
It will not build pressure after a long draw, IE running the washer, or taking a shower. If I pull the electric, the pressure will drop like a rock to zero, with the house line closed off. Then i let it sit for a few minutes and fire the pump back up and it will build pressure at a normal rate right up to the 50 PSI shut off, and hold it.
1 - 20 of 38 Posts
