1 - 20 of 21 Posts
I ran my buick last night and I think i'm very close on my tune. Nothing big, just a small plate on a sbc, 57N 53F. 975 bottle pressure, 5.5 fuel. I've been using 100 octane pump gas and I can't seem to run much timing without still peppering the plugs a tiny bit. I am pulling 14 degrees out of 36 when the juice is flowing. I have a thin and light carbon ring at the base of the porcelean and it was reading 12.0-12.2 on the AFR gauge.
Below are pics of plugs from last night. From left to right:
1)n/a pass
2)pulling 10 degrees - few black specks
3)pulling 12 degrees - even fewer
4)pulling 14 degrees - no specks
I don't have a good feeling for reading the straps. How do mine look? The next time I go out I'm going to run 110 octane leaded fuel and try to put some timing back in. This plate is taking me from [email protected] down to [email protected] I slowed .1 with all 14 degrees out.
pig hunter
black speck could be carbon burning off the top of the pistons or a little oil in the cylinder.. what engine is this and comp..
Here is the setup overview:
1984 Buick Regal
383 sbc 11:1
Forged flat top pistons w/2 valve reliefs
Eagle rods
Engine Quest Heads. 200cc intake runners, 64 cc chambers
Crower Solid Roller 00426S grind
ADV Duration 288/290 Lift .570 .584
Duration @ .050 250/252
108 Lobe Center
.026/.028 Valve clearance
Comp 1.5 Stainless Rockers
Crower springs
Victor JR intake
Holley 750 Double Pumper with Proform main body
Hooker headers, small primaries, 3" collectors
3" dual exhaust w/x-pipe, no cats, mandrel bent
700R4 Trans -built
4000 Stall 10" w/full size lockup plate.
4.11 Gears
27x11.50x15 Hoosiers
Car weighs 3450 lbs
100 hp nitrous plate system
Accel Nitrous Mastermind
Distributor locked at 36 degrees
100 Octane unleaded fuel
I had wondered if it could be carbon. Would it only leave the carbon specs when the nitrous is used? How can I tell the difference? The specks are so tiny they are hard to take a picture of.
I got a couple close up pics of the "worst" plug. Does it look like carbon?
Discussion Starter #11
Yea it does sound strange pulling that much for a small hit. That is why I'm checking with the experts here. Do the specks on the plugs look like carbon or something else? For all I know I could be pulling way too much timing.
I assume they were fresh plugs before the pass. I get the same thing on mine if I have been street driving, I usually point to the tops of the pistons getting "cleaned off" as Jeff mentioned.
Discussion Starter #13
The first pass was n/a and showed zero specks. Plugs were fresh each pass. When I've seen aluminum on plugs in the past it was more like 3 dimensional specks or gray spots.
Discussion Starter #15
What would cause that? From what I'm reading I was going the wrong way with the timing if it was slowing down.
I've seen those black specs a few times while moving tunes around. I'm pretty sure mine are usually a combination of being a little low on timing and way rich on the intermediates (burnout and on the chip).
Is it an Edelbrock Performer plate? If so is the Edelbrock suggested jetting for the 100 horse hit 57n/65f or something close to that? I ask because I have an Edelbrock Performer kit and I believe that's their suggested jetting and I think that's gonna be way off and I was wondering where to start.
Hope I don't seem to be high-jacking your thread but I'm a nitrous newb so wanted to ask. Thanks.
Discussion Starter #20
It is the larger of the two Edelbrock plates, whichever that one is. I'm headed to the track in a few minutes for some more tuning.
1 - 20 of 21 Posts
