Hey guys. I have been moving along nicely on my SBF motor, but ran into a problem. My 77 tooth cog pulley is hittin the CSR water pump. Pulley has the 6-rib on the back for my factory alternator (good idea or bad?? :smt102)
You can see in the pics its hitting the pump pigtail ( I will re-clock to fix) but its also hittin the pump motor itself, as its cocked and won't allow the blower pulley to even sit flush and bolt up to the balancer.
I was just holding the pulley up in the pic, so the angle is not EXACT to the water pump like it should be, but you get the idea.
Procharger suggested a 73, but I don't think its enough to clear, is there anything smaller??
Do I :
1-go smaller on the pulley and upsize the blower puley?
2- go remote mount?
3- get the meizere pump as I "heard" it's mounted higher and clears??
procharger will exchange my pulleys no prob, but I'm not sure I will gain enough. . .
what are you SBF dudes doing on your set ups??
Chris
Do I :
2- go remote mount?
Chris
