1 - 20 of 20 Posts
I need the best tire I can get in a max 28” tall tire on a 10” rim.
Both cars are 1993 Mustang Coupes... Specs below.
1. Turbo car @ 3350 lbs. “race weight” 2000 HP (+/-) depending on boost level.
2. Super Charger car @ 3150 lbs. “race weight” 1500 HP (+/-) depending on boost level.
Tires that I have tried. Hoosier 14.5 Quick Time Pro’s, Hoosier 235 Drag Radials and M/T 235 Drag Radials. I’m thinking about trying a slick but none of them are wide as the QTP’s so I’m not sure they would be any better... Thoughts?
Thanks!
why not the m/t pro 275?
Discussion Starter · #4 ·
I've thought about dong the 275 Pros... I've seen some amazing times with those tires. And as far a calling M/T or Hoosier, I see there are some tire reps in the section so I would think this is as good as calling them... JMHO.
You have a couple of different options, but if we are talking about "track use only", it really narrows down to the P275/60R15 ET Street Radial Pro or the 28.0/10.5-15S ET Drag. Either will work on both cars, however....
If you race on well prepped tracks and you can work with you set-up, the P275 would be the way to go.
If the tracks are tricky, and you want some consistency on those surfaces, the 28.0/10.5-15S (part # 3055S) would be the way to go.
Or you could have a set of both and try them on each car! :):p
I hope this helps,
Thanks,
Jason Moulton
you got more information than I did from them..
Discussion Starter · #7 ·
I hope this helps,
Thanks,
Jason Moulton
Thanks! I'll give both a try. We have one good prep and one shitty prep track around here so it will be a good experiment. :)
I hope this helps,
Thanks,
Jason Moulton
Sorry to thread-jack, but Jason, what would you recommend if it had to be DOT?
If it had to be DOT for track use/rules only - I'd go with the 3754X, P275/60R15 ET Street Radial Pro.
For limited (read "dry") street use, I'd go with the P275/60R15, or P295/55R15 (automatic), or 28X12.50R15LT ET Street (clutch).
Hope this helps.
Thanks,
Jason Moulton
i've noticed after the burn out tire psi increases but 1.5-2lbs.. this is on a 28x10.5w tire.. i run my tire at 11.5psi before burn out. 3270lb car...
Do you guys think that using the tubes is that necessary with a 30551? What is going to be the difference?
1 - 20 of 20 Posts
