1 - 5 of 5 Posts
Anyone out there fimilar with the Dart BC intake and how the common wall extends well into the plenum. The walls not only extends well into the plunem but they turn also so two face torwards the rear of the motor and the other 2 face torwards the front. With a plate system oriented w/the bars front to back, those common walls seam like they would block NOS from getting their fair share in the center 4 cylinders and sending more to the outer cylinders. I was curious if anyone has rotated the plate 90 degrees to address this?? Steve, Monty??
Yes, this is one of the advantages as well in using a Dominator based plate. I commonly tell guys that when they are starting out with a kit on the smaller tunes, don't be afraid to turn the plate 90 degrees and check to see if the distribution is better of worse ??
In quite a few manifolds it will be better. So don't be afraid to try it.. Thanks, SJ
1 - 5 of 5 Posts
