PipeMax version 4.40
Download Link :
http://www.mediafire.com/file/41mwmirodau5g9m/Pipe440_ZIP.zip/file
Download + UnZip + Install new PipeMax v4.40
if you then like PipeMax v4.40 ,
Purchase + Register it to receive your UnLock Code
if you do not like it ,
uninstall it or delete it .
However,
the Professional style Compression Ratio Calculator
inside PipeMax v4.40 will work "without" the UnLock Code
...its FREE for trying out PipeMax !
Also includes a "Free" Multi-Media Player
PipeMax v4.40 new changes :
added a bunch of Metric input/output Data
fixed a few "Bugs"
added + clarified many Help Texts for inputs and choices
overall new PipeMax v4.40 is much more accurate than previous versions
in modeling Camshaft , Dyno TQ and HP , Flowbench Intake/Exhaust Flow , and Dyno Weather Data
Recommends Camshaft Specs that will let your Engine achieve
the Peak Torque and Peak HP at your desired RPM .
Most times , PipeMax recommended Cam Specs will closely matchup to the Cam you had in your Dyno tests !
includes 48 example simulation files , with extensive Notes
Download Link :
However,
fixed a few "Bugs"
