stay away from heat and chemicals! use the rubber eraser (round one) on an air tool, they make spesific tools for this so turn the air way down as not to burn the paint. the rubbers are cheep, and avail. in different sizes at an autobody suply store, or use a drill. buff the area and polish after and most times you can't tell.....unless its red! lol, as stated before, if it's under the clear....you are screwed! i have gotten it out from under clear and saved the base, but then it will need re-cleared, so it's not an effective means of doing it. autobodytoolmart.com has the kit for 120 bucks, tool, and like 20 rubbers. go slow and it'll turn out fine. good luck
