1 - 3 of 3 Posts
have the YUKON pro iron "N" cas with 3;25 bearing bore and 5/8" cap bolts...what should i tourq cap bolts to????
have aluminum pinion support w/new bearings/big pro pinion and solid 2 piece w/shim bearing spacer[instead of the crush sleave]....what should my bearing preload should be????...
after i set preload by adding or taking away shims then what should i tourq pinion nut down to????
ring gear bolts are 1/2" on strange pro gears;;what should ring gear bolts be tourq to????
75ft lbs on the caps
20-25in lbs on the pinion bearing preload
final pinion nut torque should be 250ftlbs.
ring gear bolts I would ask strange, does it have the dual pattern?
Yes the ring gear has dual pattern..thanks for the specs..
1 - 3 of 3 Posts
