1 - 5 of 5 Posts
Noticed 2nd ring is tight between lands @ about 12 o'clock on piston , dressed the ring groove & noticed the top ring land has pinched the 2nd land , will i have a problem with too much ring to land clearance on the top ring? , tis around 2/3 thou , you can just see it if you look real close , have'nt got the time to get a new piston , hence the question.
TIA.
TIA.
We used to call that "BackSiding"... from being rich.. unless it's a "Hemi"....
1 - 5 of 5 Posts
