1 - 7 of 7 Posts
I bought a mustang that had a NOS plate on it. The jets are .73 nitrous and .52 fuel. I was wondering how big of a hit that was. I asked a few people and everyones eyes got big when they heard the spread. But they also are old and haven't sprayed their cars since the late 80's. The regulator is set a 7.5 pounds and the timing is at 28 degrees. It goes 7.80s on the motor and the kit is on a full throttle switch I was wondering what kind of ETs would be normal because I don't have a cage and I don't like the thought of being booted from the track. I also run 110 sunoco and it's 10.5 to 1. Any advice is appreciated. Thanks in advance.
The spread could be because of the 7.5#'s of FP...
If you have never sprayed it or been involved with the car before I would be very care full..
I don't feel I have the knowledge to tell you what to do.
If it was mine,
I would start from scratch.
i would make sure the car is tuned on motor first.
and proceed from there...
Remember Baby steps, save $$$$$
I really appreciate all the help. I agree with the baby steps. The last thing I would want is to blow it up because of a rookie mistake. Thanks again for both of you inputs.
Just start searching, and reading and reading and reading... There is a ton of knowledge on here, and almost every question and every problem in the world has happened, to someone on here....
find out which kit you actually have. then go on NOS website and follow there recommended jet size and timing starting points
1 - 7 of 7 Posts
