1 - 20 of 28 Posts
If anyone has some pics of a 62 to 67 Chevy II mini tub it would help me out a bunch thank you. Really help if there of a wagon but either or thank you again.
Check current projects at www.hrracecar.com 63 Chevy II currently getting mini tubed. Next project we will start is a 66 wagon mini tub. Several other mini tub projets in the customer pictures section. Hope these help....................Toni
KEVIN CAPS LOCK
COOL SITE!;)
Kevin, I think you may be a little prejudice towards the blue pictures! See you at Commerce today maybe......Toni
What size drag radials are under your car. Im thinking about removing the stock wheel houses and run aftermarket tubs also did it give you a lot more room to run a taller tire and let you lower the car more?
315/60 if you are refering to the blue '79 Camaro. Wheel tubs and springs are moved in.................Toni
You mean that's not really his name? I'm confused!
1 - 20 of 28 Posts
