Look I know it's been hashed in previous toipcs but I'm having a hard time being convinced to stick with the TH400 over the PG I just had built. I guess my concern is you just don't see many n/a 8.x second door cars with anything but a PG (looking for those of you who are to chime in)
Heres what were working with. The car is an all steel 64 Chevy II with glass windscreens, 2990 pounds with driver and fuel (usually a little heavier after Thanskgiving dinner
) But the floor is gone and the body sits on a tube chassis from the firewall back w/ 4link and am in the process of adding an AJE tube chassis, strut front frame. (Will loose about 200-250 pounds there)
It's a n/a small block car (660horse) with a Th400, 8" convertor that brake stalls at 5000-5100 and 4.56 gear, 14x32 slicks. The car runs 10.0 in 4200' air with a 1.32 sixty on the rear tires. The thing will hook in a car wash and,,,, in fact 'hook' has become a problem putting the car on the bumper and making the 1-2 shift about 100' out with the skinnies 6' in the air. The current suspension just isn't going to take much more of that. Either I'm dragging the bumper or dragging the oil pan. Makes for a pretty 'exciting' ride so I'm sitting out the rest of the season to add the new strut front frame and wheelie bars,,, along with some serious engine package changes.
I would have to screw up pretty bad to not make 800-825HP with the new combination, I'm loosing around 200-250 pounds off the nose of a car that already has a wheelstand problem and adding around 150+ HP.
I had a local build me a Dedenbear case PG w/ 1.80 gear set so cost of changing to PG is just a d/s and yokes and moving the trans cross member. Stepping up into the high 140mph range Im looking at changing to a 4.11 gear so that's where my delima starts....
A 2700ish pound door car w/ 4.11 gears is going to be pretty lazy with a PG through the 330 light is it not???? I need to keep the rpm's at 7000 - 7200 or less on the top end so the gear is kinda fixed. But I'm just trying to figure out if I'm going to be able to get the car up on the tire for traction and good short times with a PG. Or if I should just stick with the TH400 and hope I don't overpower the chassis and track.
Any ideas or thought from you guys running a 3spd in a heavier car like this????
TIA
TIA
